Не получается заставить работать USB-адаптер Realtek USB
Я чувствую, что буквально все перепробовал с этим.
lsusb
Bus 001 Device 007: ID 0bda:f179 Realtek Semiconductor Corp.
lsusb -t
Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/10p, 480M
|__ Port 3: Dev 7, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 4: Dev 45, If 1, Class=CDC Data, Driver=rndis_host, 480M
|__ Port 4: Dev 45, If 2, Class=Vendor Specific Class, Driver=, 480M
|__ Port 4: Dev 45, If 0, Class=Wireless, Driver=rndis_host, 480M
|__ Port 5: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 6: Dev 6, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 6: Dev 6, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
устройство nmcli
DEVICE TYPE STATE CONNECTION
br-c90a12778d6e bridge connected br-c90a12778d6e
docker0 bridge connected docker0
enp2s0 ethernet unavailable --
lo loopback unmanaged --
сеть класса lshw
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 15
serial: 4c:cc:6a:93:b4:88
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:16 ioport:d000(size=256) memory:df004000-df004fff memory:df000000-df003fff
*-network:0
physical id: 2
logical name: br-c90a12778d6e
serial: 02:42:f0:ad:98:06
capabilities: ethernet physical
configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A ip=172.18.0.1 link=no multicast=yes
*-network:1
physical id: 3
logical name: docker0
serial: 02:42:8f:77:a6:ed
configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A ip=172.17.0.1 link=no multicast=ye
беспроводном информация:
https://jsfiddle.net/websiter/L9oatjrs/embedded/js/
С помощью ndiswrapperЯ добавил netrtwlanu_Vista водитель, который, кажется, принят:(device: present - Я пробовал и других, которые, кажется, не были приняты)...
... но ничего не отображается в настройках WiFi и ничего не появляется на вкладке Дополнительные драйверы (я выбрал "Главный сервер" в качестве источника). Кроме того, в различных сообщениях и методах я читаю материал о черном списке:
Я понятия не имею, что занести в черный список и как проверить, что должно быть в черном списке.
Прежде чем купить другой USB-адаптер WiFi, я хочу убедиться, что ничего не могу сделать с его установкой (я протестировал его и работает на Windows 10).
Кроме того, есть ли список устройств USB WiFi, которые работают на Ubuntu 18?
Я далеко не знаком с Ubuntu, пожалуйста, предоставьте четкие инструкции. Если нужна дополнительная информация, дайте мне знать.
