После переустановки Alsa и Pulse Audio настройки системы отсутствуют
Я следовал: HDMI не отображается в настройках "Звука" на Ubuntu 14.04 LTS этой статьи для переустановки alsa и импульсного звука, потому что при использовании hdmi звук не работает.
Я сделал:
sudo apt-get remove --purge alsa-base pulseaudio
[sudo] password for william:
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
gir1.2-gconf-2.0 gir1.2-rsvg-2.0 python3-pyudev
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
gnome-control-center gnome-control-center-data gnome-settings-daemon
libgoa-backend-1.0-1
The following packages will be REMOVED:
alsa-base* indicator-sound* libcanberra-pulse* osspd* osspd-pulseaudio*
pulseaudio* pulseaudio-module-bluetooth* pulseaudio-module-x11*
unity-control-center* unity-control-center-signon*
webaccounts-extension-common* xul-ext-webaccounts*
The following NEW packages will be installed:
0 upgraded, 4 newly installed, 12 to remove and 31 not upgraded.
Need to get 2,351 kB of archives.
After this operation, 2,209 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main gnome-control-center amd64 1:3.6.3-0ubuntu56.1 [464 kB]
Get:2 http://us.archive.ubuntu.com/ubuntu/ trusty/main libgoa-backend-1.0-1 amd64 3.10.3-0ubuntu1 [198 kB]
Get:3 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main gnome-control-center-data all 1:3.6.3-0ubuntu56.1 [1,216 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main gnome-settings-daemon amd64 3.8.6.1-0ubuntu11.2 [472 kB]
Fetched 2,351 kB in 4s (502 kB/s)
(Reading database ... 626709 files and directories currently installed.)
Removing alsa-base (1.0.25+dfsg-0ubuntu4) ...
Purging configuration files for alsa-base (1.0.25+dfsg-0ubuntu4) ...
Removing xul-ext-webaccounts (0.5-0ubuntu2) ...
Removing webaccounts-extension-common (0.5-0ubuntu2) ...
Purging configuration files for webaccounts-extension-common (0.5-0ubuntu2) ...
Removing unity-control-center-signon (0.1.7~+14.04.20140211.2-0ubuntu4) ...
Processing triggers for libglib2.0-0:amd64 (2.40.2-0ubuntu1) ...
Processing triggers for libglib2.0-0:i386 (2.40.2-0ubuntu1) ...
Processing triggers for libc-bin (2.19-0ubuntu6.6) ...
Processing triggers for mime-support (3.54ubuntu1.1) ...
Processing triggers for gnome-menus (3.10.1-0ubuntu2) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu1) ...
Processing triggers for bamfdaemon (0.5.1+14.04.20140409-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for hicolor-icon-theme (0.13-1) ...
Selecting previously unselected package gnome-control-center.
(Reading database ... 626611 files and directories currently installed.)
Preparing to unpack .../gnome-control-center_1%3a3.6.3-0ubuntu56.1_amd64.deb ...
Unpacking gnome-control-center (1:3.6.3-0ubuntu56.1) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
(Reading database ... 626659 files and directories currently installed.)
Removing libcanberra-pulse:amd64 (0.30-0ubuntu3) ...
Purging configuration files for libcanberra-pulse:amd64 (0.30-0ubuntu3) ...
Removing osspd (1.3.2-5) ...
* Stopping OSS Proxy Daemon osspd [ OK ]
Purging configuration files for osspd (1.3.2-5) ...
Removing osspd-pulseaudio (1.3.2-5) ...
Removing pulseaudio-module-x11 (1:4.0-0ubuntu11.1) ...
Removing pulseaudio-module-bluetooth (1:4.0-0ubuntu11.1) ...
Removing unity-control-center (14.04.3+14.04.20140922-0ubuntu1) ...
Purging configuration files for unity-control-center (14.04.3+14.04.20140922-0ubuntu1) ...
Removing indicator-sound (12.10.2+14.04.20140401-0ubuntu1) ...
Purging configuration files for indicator-sound (12.10.2+14.04.20140401-0ubuntu1) ...
Removing pulseaudio (1:4.0-0ubuntu11.1) ...
Purging configuration files for pulseaudio (1:4.0-0ubuntu11.1) ...
Selecting previously unselected package libgoa-backend-1.0-1:amd64.
(Reading database ... 626270 files and directories currently installed.)
Preparing to unpack .../libgoa-backend-1.0-1_3.10.3-0ubuntu1_amd64.deb ...
Unpacking libgoa-backend-1.0-1:amd64 (3.10.3-0ubuntu1) ...
Selecting previously unselected package gnome-control-center-data.
Preparing to unpack .../gnome-control-center-data_1%3a3.6.3-0ubuntu56.1_all.deb ...
Unpacking gnome-control-center-data (1:3.6.3-0ubuntu56.1) ...
Selecting previously unselected package gnome-settings-daemon.
Preparing to unpack .../gnome-settings-daemon_3.8.6.1-0ubuntu11.2_amd64.deb ...
Unpacking gnome-settings-daemon (3.8.6.1-0ubuntu11.2) ...
Setting up libgoa-backend-1.0-1:amd64 (3.10.3-0ubuntu1) ...
Setting up gnome-control-center-data (1:3.6.3-0ubuntu56.1) ...
Setting up gnome-settings-daemon (3.8.6.1-0ubuntu11.2) ...
Setting up gnome-control-center (1:3.6.3-0ubuntu56.1) ...
william@William-PC:~$ sudo apt-get install alsa-base pulseaudio
Suggested packages:
apmd alsa-oss oss-compat pavumeter paman pavucontrol paprefs
pulseaudio-module-raop pulseaudio-esound-compat
alsa-base pulseaudio pulseaudio-module-x11
0 upgraded, 3 newly installed, 0 to remove and 31 not upgraded.
Need to get 859 kB of archives.
After this operation, 4,168 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://us.archive.ubuntu.com/ubuntu/ trusty/main alsa-base all 1.0.25+dfsg-0ubuntu4 [151 kB]
Get:2 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main pulseaudio amd64 1:4.0-0ubuntu11.1 [692 kB]
Get:3 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main pulseaudio-module-x11 amd64 1:4.0-0ubuntu11.1 [15.9 kB]
Fetched 859 kB in 2s (317 kB/s)
Selecting previously unselected package alsa-base.
(Reading database ... 626673 files and directories currently installed.)
Preparing to unpack .../alsa-base_1.0.25+dfsg-0ubuntu4_all.deb ...
Unpacking alsa-base (1.0.25+dfsg-0ubuntu4) ...
Selecting previously unselected package pulseaudio.
Preparing to unpack .../pulseaudio_1%3a4.0-0ubuntu11.1_amd64.deb ...
Unpacking pulseaudio (1:4.0-0ubuntu11.1) ...
Selecting previously unselected package pulseaudio-module-x11.
Preparing to unpack .../pulseaudio-module-x11_1%3a4.0-0ubuntu11.1_amd64.deb ...
Unpacking pulseaudio-module-x11 (1:4.0-0ubuntu11.1) ...
Processing triggers for ureadahead (0.100.0-16) ...
ureadahead will be reprofiled on next reboot
Setting up alsa-base (1.0.25+dfsg-0ubuntu4) ...
Setting up pulseaudio (1:4.0-0ubuntu11.1) ...
Adding user pulse to group audio
Setting up pulseaudio-module-x11 (1:4.0-0ubuntu11.1) ...
william@William-PC:~$ sudo alsa force-reload
Unloading ALSA sound driver modules: snd-hrtimer snd-hda-codec-hdmi snd-hda-codec-realtek snd-seq-midi snd-seq-midi-event snd-rawmidi snd-hda-intel snd-hda-codec snd-hwdep snd-seq snd-pcm snd-page-alloc snd-seq-device snd-timer (failed: modules still loaded: snd-hrtimer snd-hda-codec-hdmi snd-hda-codec-realtek snd-hda-intel snd-hda-codec snd-hwdep snd-seq snd-pcm snd-page-alloc snd-seq-device snd-timer).
Loading ALSA sound driver modules: snd-hrtimer snd-hda-codec-hdmi snd-hda-codec-realtek snd-seq-midi snd-seq-midi-event snd-rawmidi snd-hda-intel snd-hda-codec snd-hwdep snd-seq snd-pcm snd-page-alloc snd-seq-device snd-timer.
мои настройки системы испорчены:
Пожалуйста, помогите, как я могу вернуть настройки моей системы?
Когда вы чистите alsa-base pulseaudio с помощью команды:
Это удаляет следующие пакеты:
Это приводит к этому промаху, так как вы удаляете unity-control-center* и unity-control-center-signon* и другие пакеты, перечисленные выше.
Чтобы решить эту проблему, вы должны установить эти пакеты снова.
sudo apt-get install alsa-base* indicator-sound* libcanberra-pulse* osspd* osspd-pulseaudio* pulseaudio* pulseaudio-module-bluetooth* pulseaudio-module-x11* unity-control-center* unity-control-center-signon* webaccounts-extension-common* xul-ext-webaccounts*
Если это создает проблемы, то лучше установить один пакет за один раз.
