Проблема с переменным путем: команда conda не найдена
После установки Anaconda правильно. Я хотел после завершения установки сделать следующее. Я забыл сделать это при установке anaconda:
export PATH="/root/anaconda3/bin"
conda --version
conda command not found
потом я открыл
gedit /root/.bashrc
Я добавил в конце файла
прикладом я все еще получаю
conda --version
РЕДАКТИРОВАТЬ1: gedit /root/.bashrc
# ~/.bashrc: executed by bash(1) for non-login shells.
# see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)
# for examples
# If not running interactively, don't do anything
[ -z "$PS1" ] && return
# don't put duplicate lines in the history. See bash(1) for more options
# ... or force ignoredups and ignorespace
HISTCONTROL=ignoredups:ignorespace
# append to the history file, don't overwrite it
shopt -s histappend
# for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
HISTSIZE=1000
HISTFILESIZE=2000
# check the window size after each command and, if necessary,
# update the values of LINES and COLUMNS.
shopt -s checkwinsize
# make less more friendly for non-text input files, see lesspipe(1)
[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)"
# set variable identifying the chroot you work in (used in the prompt below)
if [ -z "$debian_chroot" ] && [ -r /etc/debian_chroot ]; then
    debian_chroot=$(cat /etc/debian_chroot)
fi
# set a fancy prompt (non-color, unless we know we "want" color)
case "$TERM" in
    xterm-color) color_prompt=yes;;
esac
# uncomment for a colored prompt, if the terminal has the capability; turned
# off by default to not distract the user: the focus in a terminal window
# should be on the output of commands, not on the prompt
#force_color_prompt=yes
if [ -n "$force_color_prompt" ]; then
    if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
    # We have color support; assume it's compliant with Ecma-48
    # (ISO/IEC-6429). (Lack of such support is extremely rare, and such
    # a case would tend to support setf rather than setaf.)
    color_prompt=yes
    else
    color_prompt=
    fi
fi
if [ "$color_prompt" = yes ]; then
    PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
else
    PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
fi
unset color_prompt force_color_prompt
# If this is an xterm set the title to user@host:dir
case "$TERM" in
xterm*|rxvt*)
    PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1"
esac
# enable color support of ls and also add handy aliases
if [ -x /usr/bin/dircolors ]; then
    test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)"
    alias ls='ls --color=auto'
    #alias dir='dir --color=auto'
    #alias vdir='vdir --color=auto'
    alias grep='grep --color=auto'
    alias fgrep='fgrep --color=auto'
    alias egrep='egrep --color=auto'
fi
# some more ls aliases
alias ll='ls -alF'
alias la='ls -A'
alias l='ls -CF'
# Alias definitions.
# You may want to put all your additions into a separate file like
# ~/.bash_aliases, instead of adding them here directly.
# See /usr/share/doc/bash-doc/examples in the bash-doc package.
if [ -f ~/.bash_aliases ]; then
    . ~/.bash_aliases
fi
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
#if [ -f /etc/bash_completion ] && ! shopt -oq posix; then
#    . /etc/bash_completion
#fi
Я также сделал следующее:
 echo $PATH
/home/ahmed/anaconda3/bin:/home/ahmed/anaconda3/bin:/home/ahmed/anaconda3/bin:/home/ahmed/anaconda3/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
Что не так с моим кодом? Есть много пути на этом пути!
Попробуйте добавить строку ниже к вашему .bashrc файл
export PATH=~/anaconda3/bin:$PATH
тогда попробуйте:
conda --version
чтобы увидеть версию
Давайте исправим это так:
  1. Уберите это из /root/ с:
    sudo mv /root/anaconda3 /home/$USER
  2. Добавьте это к /home/ahmed/.bashrcпожалуйста, не используйте "sudo" здесь просто сделать nano /home/$USER/.bashrc:
    # Anaconda3
    export PATH="/home/ahmed/anaconda2/bin:$PATH"
  3. Источник .bashrc файл с:
    source /home/ahmed/.bashrc
  4. Теперь удалите запись [export PATH="/root/anaconda3/bin"] в /root/.bashrc с nano editor или с редактором, который вы использовали раньше
  5. Откройте новый терминал и проверьте
Сделайте следующее:
  1. Добавьте этот путь в ваш файл.bashrc export PATH=~/anaconda3/bin:$PATH или путь к мусорному ведру вашей анаконды
  2. Затем снова откройте свой терминал
  3. Тип conda --version
Убедитесь, что вы устанавливаете двоичный файл Anaconda, совместимый с вашим ядром.
Я был в такой же ситуации. Выяснилось, что у меня процессор x64_86, и я пытался установить 64-битный установщик Power 8. Вы можете узнать то же самое для вашего процессора, используя следующую команду. Он дает вам основную информацию о программном и аппаратном обеспечении компьютера.
$ uname -a
https://www.anaconda.com/download/
На странице, приведенной выше, отображаются два типа 64-разрядных установщиков.
  • 64-разрядный (x86) установщик и
  • 64-разрядный (Power 8) установщик
