Dual GPU, Dual monitor: второй монитор черный с тенью мыши
У меня есть монитор, подключенный к каждому из моих GTX 980 Ti, на Ubuntu 16.04. Настройка NVIDIA X Server успешно обнаруживает два монитора и два экрана с абсолютной позицией screen1, установленной на +1920+0.
Вот мой файл xorg.conf:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 375.20 (buildd@lcy01-26) Sat Nov 19 12:38:43 UTC 2016
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" RightOf "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "ViewSonic VX2433wm"
HorizSync 24.0 - 82.0
VertRefresh 50.0 - 75.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "ViewSonic VP2365WB"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 980 Ti"
BusID "PCI:1:0:0"
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BusID "PCI:2:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-0"
Option "metamodes" "nvidia-auto-select +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "Stereo" "0"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Тем не менее, мой второй монитор (Monitor1, Screen1) пуст (черный). Но странная часть: я могу переместить свою мышь на второй экран, и я увижу черный крест с белыми границами там, где должна быть моя мышь. Я не вижу ничего на этом втором экране (все черное) и не могу перетащить на него окно.
Вот результат работы: sudo lshw -c video
*-display
description: VGA compatible controller
product: GM200 [GeForce GTX 980 Ti]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:135 memory:de000000-deffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:e000(size=128) memory:df000000-df07ffff
*-display
physical id: 0
bus info: pci@0000:02:00.0
version: a1
width: 64 bits
clock: 33MHz
resources: irq:136 memory:dc000000-dcffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:d000(size=128) memory:dd000000-dd07ffff
Я попытался поиграть с xorg.conf, а также с настройками сервера NVIDIA X, но пока ничего не получалось, и мой второй монитор все еще пуст. Эта проблема была поднята, когда я обновился с 14.04 до 16.04. У меня двойная установка ОС с windows, а второй монитор в порядке на другой моей ОС.
После нескольких дней неприятностей я наконец нашел решение или, возможно, просто обходной путь: настройка нескольких мониторов не сработает, если вы не включите Xinerama в настройках nvidia.
Для этого:
открыть терминал, написать
sudo nvidia-settings
В настройках дисплея X-сервера включите Xinerama
Сохранить в X Файл конфигурации (вы можете создать резервную копию вашего файла xorf.conf до этого шага). Закройте окно настроек.
- В терминале беги
sudo service lightdm restart
